Solved! Go to Solution.
Good hint.
Switch airplane mode on: GPS works
Switch airplane mode off: GPS continues working !!!!!
It was just a short test. I think the Xperia M2 has a great piece of software.
After 15 minutes continuos GPS FIX the problem is back.
It is record-time for my M2 under Lollipop
In android KitKat when i connect my phone to car headset - Android showed up information about pairing, and then phone book access.
In 5.1.1 after update i cant connect my phone because new android forces access to adress book, and in settings is no way to change it. With phone book access phone and car are disconnect.
This update is terrible. I cant use this phone in car because GPS will not work and there is a problem with bluetooth....
Sorry for my english..
yep, to add to the GPS issue I have (we all have.) I've also just noticed the Bluetooth music streaming to my car stutters after a while. resetting the bluetooth seems to correct but after a few songs, or skipping tracks, it starts stuttering again.
My M2 aqua is unrooted, is their a way to roll back my phone to KitKat? that was perfect....dunno why I updated it??!!
You can roll back to Kit Kat with Flashtool, there is no need to root. With Xperifirm, which is integrated in Flashtool, will you'll find the previous firmware from your operator.
I have downgraded to Jelly Bean 4.3 because I think it has no bugs that newer versions suffer from.
thanks George, I'll check that out....dunno how long we'll be waiting for sony?!
