Battery draining fast
Srinivassenu
Visitor
Hello, in my phone im facing battery draing problem... Plz suggest what to do in 5 hr it will drain 15% without wifi on so plz suggest
Thank-you
12 REPLIES 12
YoGem
Leader
Can you go in settings, battery and taking a screenshot of that page and posting it here? To take a screenshot press volume down + power.
Deadbrian96
Visitor
I feel the same, the battery runs out quickly. I went to sleep with 50% and I woke up with 13%. And it puts you've been using the wifi battery when it had removed.
Srinivassenu
Visitor
How to upload image hear
Srinivassenu
Visitor
Same hear bro so ill off ma wifi before going to sleep😔😔
Uliwooly
Simple, scroll to the bottom > FULL > you should be able to upload the picture.
Srinivassenu
Visitor
There is no option to upload image Bro.....can u contact me.
Srinivassenu
Visitor
Any one suggest me
moravia
Visitor
@Srinivassenu wrote:
Any one suggest me
My battery drains even faster... It's like couple of hours of battery and thats after the recent update for fixing bugs.. Please help
Srinivassenu
Visitor
Guys in my mobile it will switch off automatically though der is a battery around 50%
It's show low battery even 50%
