Hy, i have Xperia M dual, I need to root my phone for the gaming purpose i dont change in firmware and bootloader so my warranty is void or to be continue. if i remove some pre-loaded apps then?
if you root your phone you could void your warranty, same goes for the bootloader, you could void your warranty, know that if you do unlock the bootloader you will lose the DRM keys and other features might not work
but i need to play more then 1 GB game and Xperia™ M dual dont have more internal space. how can i play ?
If you are fully aware of the risks involved, and have a deep knowledge about these technologies, continue to the unlock boot loader instructions page.You should be aware that unlocking the boot loader will not give you root access. The only way to get root access is to flash a custom ROM with root access.
http://unlockbootloader.sonymobile.com/
Thanks, but using this article i root my phone and i save my warranty ?
its better not to unlock the bootloader. again there's always a risk
i know there is much risk but need only clarification about warranty void issues .
