Xperia L1 lock screen wallpaper
Paulkent63
New
I've had this device for 2 years now. System update is current.
When I set a lock screen wallpaper, it says'set', but doesn't work.
It used to work just fine.
Can anyone help please.
8 REPLIES 8
profile.country.NL.title
Strampke
First attempt: already tried another wallpaper?
Paulkent63
New
I've tried many!
All without luck.
It used to work so I'm at a loss as to the problem.
Strampke
Then for instance set a wallpaper for both lock screen and home screen.
When that works, set another wallpaper for the home screen.
Another thing to try:
Settings -> apps & notifications -> find Xperia Home -> tap Storage & Cache -> Clear Cache
Thomas301
Member
I am having the same problem with my Sony Xperia L1 and are trying this, but in the settings it only says apps. Wallpaper for Lockscreen and Home screen and no vibration on unlock pattern doesn't work after factory restore.
Anonymous
Not applicable
Hi there,
As per the version on your Xperia L1, apps is the one you should press on it then you will find Xperia home app.
You can check check here to enter the vibration settings on your phone.
Thomas301
Member
Shall I try force stopping the App?
Anonymous
Not applicable
Can you mention which app exactly?
Anonymous
Not applicable
