- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There will be no software update,only software repair.You can factory settings reset.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Could you take a screenshot of the error?
Screenshot = press and hold power & volume down at the same time
you are not going to damage your phone if you force close an app
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you get any more erros you could re-install the latest updates, also if you have taskillers, antivirus, battery apps, etc, they could be creating this issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm sorry but isn't there any other solution? If i cleared the app's data would everything be fine?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You could try this to reset stamina mode:
First,disable stamina mode.After,go to settings-apps-all-eco mode controller,force stop it and clear data.Restart your phone and enable stamina again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ahhhh eco mode controller not in all apps..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How can that be?Try reinstalling with sony update service,it should show up there.
