Wireless Issues reported on BDP -S6200
SOLVED
bigredbus2
Member
Just a FYI (and I don't know why)
Wherenever I start my BDP -S6200 up, it reports problems with the wireless connection. If you ignore the message and just carry on, all is well. I don't know why it is doing it - anyone else had this problem ? - did a good old fashioned ctrl-alt-delete fix it ? (or even a complete power down and up again) ?
1 ACCEPTED SOLUTION
Accepted Solutions
bigredbus2
Member
The update sorted it.
1 REPLY 1
bigredbus2
Member
