- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SVR-HDT500 Audio Clicks & Pops
Has anyone else noticed that the audio on all HD channels has recently acquired splats, clicks and pops?
I have had this problem on COM7 channels (BBC4HD, BBC News HD...) since they started in December 2013, but recently this problem has spread to PSB3 channels (BBC1HD, BBC2HD, ITVHD, Channel4HD), when they were fine before. The received signal is good, and there are no picture break ups to indicate that there is a reception problem.
The broadcasters have certainly changed something on the PSB3 multiplex mid-October, but what I am not sure about is whether the audio decoding software in my PVR is at fault, or whether it's the broadcaster at fault. Reading on other forums, I know this problem is affecting other makes of PVRs.
Thanks,
Justin.
![](/skins/images/8F5409FB983461670F0A358BFAFFAC26/responsive_peak/images/icon_anonymous_message.png)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I have the same PVR recorder, however I have not used it in a while - I'll get back to you when I test it out and see if I also experience this issue (however it wont for a couple of days).
Also, you say about other forums - I dont suppose you know if everyone is on the same transmitter - as it could be a simple case of a 'rogue' transmitter.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I receive my signal from Emley Moor transmitter. Other people who are now complaining about this problem, from at least one other transmitter and recorder make, are to be found here: https://www.avforums.com/threads/digital-stream-dhr-8203-5u-hd-pvr-master-thread-part-twelve.1686714...
I made a thread of my own - https://www.avforums.com/threads/psb3-mux-audio-clicks-and-pops.1914401/#post-21319523 - in which I indicated that the problem has coincided with some form of transmission change on PSB3. On this thread I have also posted an example of what I hear, although I inadvertently reduced the clarity of the splutters and splats.
This problem is either a broadcaster or receiver software fault. If it's a receiver fault, I really think Sony should fix it because this problem first started when my recorder was only 2 years old, so I don't think I have had full use of it before it has been rendered obsolete by transmission changes.
Thanks,
Justin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
I have had my HDT500 on HD channels for the last couple of hours now, with no incident. However no channels have been broadcasting 5.1 as of yet (only 2.0 stereo). So cannot test this on mine. However I have been reading the other threads that you linked to, and I can see that many are complaining across many different devices and manufacturers - therefore this is unlikely to be specific to Sony.
PS : Im on the Oxford transmitter.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I don't know if 5.1 audio is a factor in this.
From the other threads, I gather that engineers for Vestel and Digistream recorders are looking into the issue. It'll be interesting to know their findings - either the broadcaster has violated the Freeview HD specification, or my PVR doesn't meet it.
Thanks,
Justin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
As another person has also reported the problem:
http://community.sony.co.uk/t5/general-chat/svr-hdt1000-audio-dropouts-issues/m-p/1830063
I have reported this to Sony in the hopes that they can assist in resolving this.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for reporting this problem to Sony. I hope it gets resolved.
Justin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It appears the problem is being caused by broadcasters switching from Dolby Multistream 10 to MS11. Sony probably already know this.
Now, whether the fault is caused by the broadcaster poorly formatting the MS11 data, or the software in our recorders is faulty, always was faulty, and is not capable of ignoring the additional data when it should be able to, I don't know.
Justin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Received a message from Sony that they can confirm the problem, which means that they can replicate it too. So good news so far.
Ill keep you posted when more updates comes to light
Cheers
