Could anyone advise as to how I can control the sound on my new Sony HT-CT660 sound bar using my Sky remote? If possible, what is the code? The supplied paper instructions are frankly baffling. Thanks.
I have had a quick Google, and the codes SONY use appear to be 1086 or 1186 or 1286 or 1786
instructions on how to input the codes are HERE
Much appreciated. I'll try that. Thank you.
None of these codes have worked, tried these and more from online but nothing worked. I am frustrated simply because I had it working before now.
HELP!!
Did you find a solution?..i have the same issue, it DID work - not now tho.
