Hello,
I just ordered this model of home cinema and I want to ask you how can I be able to play 3Dbrays.
I saw that in the description says "Blu-ray 3D™ via software update - Play Blu-ray 3D™ content (with a software update)" so my question is how can I update it's software?
From where can I download the update and how exactly to install it?
I know that sony doesn't usually offer firmware updates so I wanna profit now.
Thanks,
Mugurel
Solved! Go to Solution.
I have just upgraded my BDV-F500. The process is as follows.
or
It's very simple really...
Hope this helps.
David
or
Hope this helps.
David
