Problem with Universal Remote Control
profile.country.bg_BG.title
MMateo
Visitor
Hi everyone.
I have a Sony STR-DB725 Reciever but I don't have the original remote control for it.
I bought a universal one but i cant make it work :smileysad:. I red all the manual of the remote controll but it wont work.
If someone can help me please i`ll be grateful.
Thanks.
This is the remote control
http://www.tpetrov.com/pictures/jpg/psupertel.jpg
1 REPLY 1
Thalamus.
Champion
Hi MMateo,
welcome to the Sony User Community..:smileyhappy:
If you have folowed the instructions & none of the supplied codes have worked then I would recommend contacting the remote manufacturer for futher assistance..
If they are unable to help resolve your problem then according to a user guide I located on the net, it states that remote supplied with your STR-DB725 was a RM-LJ301..
Have a search on the net you may be able to locate a replacement..
