ZV-1 Strange Shutter Noise
Explorer
I'd appreciate some advice about my brand new ZV-1 please. There's a strange metallic/vibration-like ping noise immediately after I press the shutter to take a shot. I've owned countless cameras over the years, including several with leaf shutters, and I haven't heard this before.
It isn't loud, but it is audible to me in a quiet room at normal hand holding distance. Putting my ear close to the camera and the noise is very distinct.
I'd be very grateful if ZV-1 owners could listen closely to their camera and report back.
2 REPLIES 2
jumpsuit
Hi @Photo19  and welcome to the UK Community :slight_smile:
I've just tested my Son's ZV-1 but I didn't hear anything like you described.
The only noise made after pressing the shutter was the electronic shutter sound and there was
no noise after I turned that off.
Have you tried silent shooting mode to see if that's any better/worse?
Explorer
Hi, many thanks for the reply.
There are no odd noises when using the electronic shutter. The noise occurs when the leaf shutter is in operation, it’s a ‘ping’ sound at the same time as the normal shutter sound. I have quite sensitive hearing so I can hear it in a quiet room, but others may need to hold their ear next to their camera - at which point it’s quite distinct.
I think leaf shutters do contain a spring, but none of the other leaf shutter cameras I’ve owned over the years (including two RX100 models) have made this sound. I'm curious as to whether it's a fault, before I raise a return for the camera.
