RX100M4 battery very fast used
profile.country.DK.title
pederhoy
Explorer
The battery in my RX100M4 is stille very fast used, even aften update to software ver . 2.0 and resetting of the camera. If I do not remove the battery, it is flat after one night 😞
I hope someone has an hint to avoid this problem:-)
Tags (2)
7 REPLIES 7
EMS_MO72
Hey @pederhoy
did you try to test another battery with the camera and check?
pederhoy
Explorer
Hi @EMS_MO72,
I actually have 4 batteries, genuine SONY batteries, and it makes no difference, with one I use 😞
I suspect it is caused by som software bug …
Piscie
Hey @pederhoy, you might want to try resetting the camera to factory settings (menu - setup - setting reset - initialize). Also check the software version on your camera, is it version 2.00?
pederhoy
Explorer
Hi @Piscie
I already tried both of your suggestions. Software version is 2.0 and I did reset the camera to factory settings twice. Despite of this batteries rapidly loses power …  and very often the ON/OFF button does not respond (may be because of low power level ??? )
Tags (2)
Piscie
Hey @pederhoy, I'm afraid it seems a hardware related issue then. I'd recommend contacting the Sony reps directly to let you know the repair process
pederhoy
Explorer
Hey, @Piscie
Thanks for your reply and advice. I already asked a dealer for repair prices, and I am afraid it makes no sense trying a repair … it will be far too costly 😕
Tags (1)
Piscie
Hi @pederhoy, is the camera out of warranty with Sony? You can still check the repair process directly with them
