I would like to split display from my RX100 Mk3 because the camera is too heavy for my Phantom 2 drone. Is it possible? Is the camera going to work properly without the display?
Hi @artzamur and welcome to the Community
Do you mean remove the screen?
I personally wouldn't as even if the camera does still work
then it will definately void any warranty you have.
Hi @artzamur,
I am sure no one can give you a definitive answer to that question.
I wouldn't do that personally, rather I would recommend to use a Sony Action Cam (preferrably FDR X3000) or get the RX0.
- Nic
Thanks jumpsuit. Yes I mean remuve the screen. If the camera works without the display I have nothing to lose because there is no more warrenty.
Hi lamNic, FDR X3000 and RX0 are good for movies but very poor for still photos. I take only still photos.
You are right for the FDR X3000, yet the RX0 is a photo camera first and foremost.
Though I assume you are talking about the zoom and focus features which the RX0 is missing.
- Nic
You are right Nic. RX0 is a great camera, but for wideangle lens I already have a good solution: Ricoh GR with 28mm F 2.8 and APS-C sensor. Untill now I have used RX100 Mk1 for tele lens, but it is 1,8-4,9 aperture and RX100 Mk3 has 1,8-2,8 aperture (better for lightless subject).
