RX100 M2 Mechanical noise
MrHackenbacker
New
My RX100 ll has developed some sort of mechanical noise akin to an electric shaver when in use which is very annoying. I have done a reset but this hasn't made any difference. Has anyone else had this problem, and if so is it easy to have fixed if I send it back to Sony?
3 REPLIES 3
SkyNet404
Specialist
Hey,
I would recommend getting in touch with Sony support as right now based on what you said it might needs to be inspected by an engineer.
Cheers.
MrHackenbacker
New
Thanks Skynet404, I have come to the same conclusion. I've sent it back and it's being looked at by Sony as I write.
Cheers.
Piscie
Hey @MrHackenbacker, keep us updated with their outcome!
