Lens for h300
profile.country.GR.title
sofaki87
New
Lens for h300
I want to buy Lens for my h300 and I dont know which is  compatible.is anybody knows to help me?
3 REPLIES 3
profile.country.DE.title
IamNic
Hi @sofaki87,
if you are talking about the DSC-H300, then you have a so called "bridge camera" with a non-removable lens.
- Nic
sofaki87
New
Thanks for your information IamNic!Do you know so if I can buy a good filter for this camera?
IamNic
Hi there @sofaki87,
I don't see any thread to screw a filter on, so I assume due to the inner part of the lens extending, it would lead to problems if you had a filter on.
- Nic
