Filter for Sony DSC-HX400V
SOLVED
Can anyone tell me if it is possible to fit a UV filter to this camera?
Many thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi stcoleridge and welcome.
Your camera takes a standard 55mm screw-in filter.
https://www.amazon.co.uk/Hoya-55mm-Digital-Screw-Filter/dp/B002L6BXYI
:wink:
2 REPLIES 2
Blencogo
:wink:
Many thanks!
