I would like to see a firmware update for the DSC-HX5 so that on startup, the zoom is the equivalent of a standard 50mm lense please? Or make it an option in the menu?
Please reply if you support this suggestion.
Richard
Hello
Welcome to the Sony forum and thanks for taking the time to post your feedback.
I can certainly see where you are coming from, especially with the option to dictate the focal length of the lens at start-up. Obviously I can’t promise it will happen, but I can make sure your request finds its way to the folks in the Cybershot product group; this is after part of the reason we set-up this forum.
Best regards
Lee
