xperia c4 dual touch problem
krishna_5255
i purchased c4 last month and very happy at that moment but next day itself i found the piece is defect as i couldnt get signals and speaker problem as well that was replaced by the shop where i purchased the cell. now i am facing problem with the touch. it is not working and its working aotumatic and deleting changing every thing in my phone. as i was in a remote location now calling someone is also becoming difficult for me and was angry with the mobile and wanted to hit it to the ground but money is coming in to mind.previosly i used arc s and c models but not faced any problems.DIDN'T EXPECT SUCH KIND OF PRODUCT FROM SONY & I WISH TO HEAR FROM THEM ABOUT THIS PROBLEM
27 RISPOSTE 27
Arkaprava
HAve anyone got solution of the problem please reply totally dissapointed buying this product!
sumantaadk
My problem is solved by hitting every corner of the touch screen.
Novli
please help me
i have same problem and i want to flash my phone using flashtool from developer.sonymobile.com
it's gonna works???
Novli
just hit every corner and done??
Raaj1454
How can update my c4 in 6 version
gunaji
i am also facing same touch pad problem with my xperia c4 dual.
i had done repaire using pc companion but problem solved by this is just for small time again same problem start.
i had update mobile 5 to 6 times using pc companion but the problem is still remain. touchscreen goes wild when touch.
Even sony service centre not helping in this issue. I dont expect such service from SONY . very disappionted with sony service. please check your update on pc companion and c4 dual model and rectify problem. This issue is damaging your image in mobile market from very long time.
if such things continuos i will suggest that dont buy such product from sony.
 please look into matter and let me know.
regards
gunaji
kahout
i have Xperia C4 Dual, i upgrade the software v. 27.3.B.0.129
i am facing now problem with touch screen, it is not working and now because of this problem i reset my phone but the problem is same. the software have some problem.
your cooperation is required.
Katipunero
I have the same problem with my Xperia C4, and now I am starting to lose my patience.
vasu31
i am sony lover, facing same issue xpreia c4dual touch issue. i am 4 time software ripper but no use. i hate every sony product plz solve the issue sony team your market is down
Nuyu861
Me have a same issue. Please fix it. ASAP.
