There is nothing like my screenshot
Ore no gense nani mo nai
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you trying to take a screenshot, if you are, just press and hold power & volume down or long press the power button (a pop up menu will appear)
