piter1984
Explorer
X80C HDR update
I've seen that the 2016 uhd models xd75 xd70 and sd80 get  hdr firmware update.Will x80c get hdr update??As I know its almost the same as xd70.
13 REPLIES 13
Hi @piter1984,
sorry but:
http://presscentre.sony.co.uk/pressreleases/sony-expands-high-dynamic-range-compatible-range-on-2015...
"In addition to the previously announced X94C and X93C series, Sony is also adding HDR compatibility to the X91C, X90C, X85C and S85C series via a network update"
XD70 and X80C aren't the same TV...
piter1984
Explorer
So there is no way to x80c get hdr??
Unfortunately no...
piter1984
Explorer
but why when i go to settings and go the enhance for the inputs it says "includes HDR"??
piter1984
Explorer
Some people says thatt he X810C does support HDR but only through streaming services such as Amazon Instant for example. It will not support HDR content over its HDMI inputs
piter1984
Explorer
And one guy from sony comunnity US said that he spoke to a Sony representative and, after he looked at the 810c's updated specs, he confirmed that the 810c does support HDR10 via HDMI (when switched to the Enhanced setting)
piter1984
Explorer
US X810C is EU X80C
Maybe in Europe is an issue of the firmware (MENU)...
piter1984
Explorer
The X80C have 8 bit or 10 bit panel??Can WCG (wide color gamut)can be a firmware update??
