Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Solved! Go to Solution.
KDL 50W 685
thanks
Ive sent you a PM with some instructions. Let me know how you get on.
Cheers
Thanks
tried on fat32 and ntfs stick too, but the tv starts normally, it appear that usb is connected, but update not start
Have you any idea why ?
Regards
Can you try another USB port? Also, is the file on the root of the USB drive?
It has only one USB port, and yes i copied to the root of the disk
Try reloading the firmware once again, just in case. But if that still doesnt work, Unfortunately i can only request that you contact Sony support. the instructions i sent seems to work for most people, but for some reason not everyone.
See:
http://www.sony.co.uk/support/en/contact
Sorry
Hi,
Sorry to hijack the thread but you seem really helpful!
I am having issues updating the software on my KD-49X8005C. I just bought it on Saturday and it seemed to set up OK (Channels all there, works well with Sky, Netflix working etc) but when I tried to access things like Prime Instant Video and other streaming services like ITV, Channel 4 etc it said a software update is required.
When attempting the update, I get up to 93% and then it fails, every time. This happens on both WIFI and ethernet. I did attempt it also on USB (formatted it to FAT32) but although I get a little gray box saying USB Device is connected, I can find no way to access the USB device from the remote control buttons and I have tried them all!
I am currently running Software Version: PKG2.287.0010EUB if that helps.
Thanks in advance.
SJ
Hi!
I have the same issue with my 50w755 i bought it today, but i cannot install the update even from USB the tv recognizes the update starting to copy and after a second its restarting..
Could you please tell me the solution too?
Regards,
Zsolt
Hi there
Sent you a PM with the instructions. It seems to work for most, but for some reason not all. Let me know how you get on.
Cheers
