Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Solved! Go to Solution.
Hi there
Unfortunately this is a known issue, however there is a fix. I have sent you a private message with some instructions. Please let me know how you get on.
Cheers
Hi there
Cheers
Thank you, your fix solve my problem, tv is updated. Thanks again!
Your Welcome. Glad it worked!:smileythumbsup:
Hi Quinnicus!
I'm having the same problem alot of people have, I've got the kdl-43W755C, when applying a software update, it stops at 70%ish, won't update, even with the usb method. Please help!
Thanks in advance!
Hi there @Nibzzx
I have sent you a private message with some instructions. Let me know how you get on.
Cheers
Many thanks, this worked perfectly! Much appreciated!!!
Excellent - thanks for confirming
Hi Quinnicus,
Could you please help me too? I have the same problem as the others above with 50W755C.
Thanks.
Hi @zlaci90
Ive sent you a private message with some instructions. Let me know how you get on
Cheers
