SONY KDL-50W755C Remote unresponsive after standby
Maxim.xxxl
Explorer
Software version: PKG3.317.0102EUA
After switching the television on after stanby controls do not work - neither from remote control or using the buttons from the back of the TV.
12 REPLIES 12
profile.country.en_GB.title
matrigw69
Explorer
Work around for now. Instead of switching the TV off at the wall and back on again. I use the TV side view app on my i-phone/pad also works on android. Use the TV remote control in that app to switch the TV off and it comes back on again with sound and a responsive actual remote control. Hopefully Sony will fix the issue soon.
Todd543
Explorer
Hi does anybody know how to fix the issue with the siny bravia RMT-TX100D,thet will not turn on or stay on,nor will the android apps load up,please help!!,it's driving me nuts two weeks without a tv now =(
velchuri
New
Few checks, try one by one and see if we got any luck.
1. check batteries in the remote.
2. Power Off and ON the TV, thenUpgrade TV OS
3. Remove recently installed apps especially if any music/Audio related Apps.
4. Remove all external devices like any USB or disk drives
5. Finally if nothing works, Call for support.
All the best
