Slow EPG on KD-55X8505C
SOLVED
profile.country.FI.title
Yo-cos
Explorer
Hi, relatively new Bravia with Android updated to 3.533 has slow EPG, when activated sound goes off for few seconds and even the guide comes up in a second, it goes black for couple of seconds. Then viewing guide no problem, but when exiting screen goes black and sound off for 3-5 seconds.
Any setting causing this or just bad app?
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
This is a known problem and is resolved under the Marshmallow (Android 6.0) update.  Sony will/should be re-starting rolling out this update soon.
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2040066#M48
Cheers
2 REPLIES 2
Anonymous
Not applicable
Hi there
Cheers
Yo-cos
Explorer
Sounds good. Thanks for the information!
