Sideloading Demo
khallergard
Member
Sideloading Demo
Have tested ES File Explorer, X-plore and Astro File Manager (sideloaded) https:///vigyaQjFx2M
3 REPLIES 3
khallergard
Member
It was pointed out to me that Pushbullet is much faster for file transfers.  Made a quick demo https://youtu.be/aHEPEuqUsm8 - does not always work for me and max 25 MB file size.
khallergard
Member
Found the AirDroid app, which can transfer files directly to the Android TV from my Android Tablet, where I create the backup apks.  No need for a go-between (cloud or usb)  https://youtu.be/ddtK6IMLINQ
Quick demo of AirDroid transferring files directly between Android Tablet and Android TV, without go-between. Written companion: https://tinyurl.com/y5kam8me Android: https://goo.gl/vmhxq4 Smart TV: https://goo.gl/l3zycf
khallergard
Member
Found Air-Share for file transfers and its Air-Launch, which can sideload directly from an Android device to an Android TV. https://youtu.be/B2c_v1leeT4
