Havnt really found much online, but what the difference between the two?
Hi there
Basically the difference is that the W805C TV is Active 3D, whereas the W755C is not 3D at all.
Cheers
Thanks quinnicus, i dont see any extra buttons either on sideview or the remote for the 3d setting, does this autoswitch when watching 3d content ?
just as a side note, wireless is now solid with this, however mirroring still fails to register so looks like a phone update rather than a tv one
Hi there
There is actually a 3D button on the SideView remote control app but not on the TVs remote control itself. You must go to the 'Action Menu' for this.
Having said that, see: https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2126443#M41214
Cheers
Thanks, will give that a try, is there a preffered set of 3d glasses to buy / use
edit, can i use a cheaper brand of active 3d glasses with this tv or is there a reason to go sony ?
