KDL-43W756C Android TV Bravia 2015 clock keeps losing time
I've noticed that the clock is always losing time. I've tried to set to automatically gets the time from the internet network (which works fine on other devices I have at home), from the broadcast, but it doesn't get the correct time at all. I've tried by setting up manually but the day after was about 40 minutes behind the correct time. Anybody with a similar problem?
How to fix this?
I've update to the latest February firmware.
It is possible to get back to the previous firmware?
1 REPLY 1
Anonymous
Not applicable
Hi there
Unfortunately this is a known issue:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2130112#M41351
In regards to rolling back firmware - it cannot be done.
Cheers
