KD55S8005C 4K tv HDR and HDMI 2.0a support
SOLVED
Turtle711
Explorer
Does any one know if my Sony to KDS8005c 55 inch 4k TV supports HDR and HDMI 2.0a as no seems to be able to help me here, I called Sony before buying the tv and they said it did support it now after purchasing the tv they said over email it doesn't but on firmware update v2605 it says it includes HDR support so now I'm confused and annoyed at Sony! I bought the tv ready for 4k blu-Ray's now it seems like a waste of money. Any advice would be great thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
At the time this thread was created, there was much confusion over which models supported HDR. However I can absolutely confirm that this model does NOT support HDR.
See this thread below for further reading:
https://community.sony.co.uk/t5/android-tv/netflix-hdr-firmware-update-12th-april-kd49x8005cbu/td-p/...
Cheers
5 REPLIES 5
Anonymous
Not applicable
Hi there
YES and YES.
I think the confusion is because it was initially not supported/implemented when the TV was first released, but due to firmware upgrades begining in Oct 2015, HDR and the HDMI 2.0a was added.
Cheers
Turtle711
Explorer
Cheers, I'm just a tad confused though how come there is no HDR mode on the TVs settings? Also the Sony support team just keep emailing telling me that this model doesn't support HDR? But they are all foreign and there is definitely a communication barrier they don't seem helpful at all
Marvbuster
Explorer
Hi, is this really true? The kd-55s8005c is able to display HDR signals coming from a ps4 game for example? I need this to be confirmed, most of the resources say otherwise, since that Model is lacking a triluminos Display...
Can someone officially confirm or deny?
Regards.marv
Anonymous
Not applicable
Hi there
Cheers
Marvbuster
Explorer
hi and thanks for your quick reply.
this had to be too good to be true. what a pity.
regards
