KD-43XF7596 starts alone, why?
@dorian.hodisan wrote:KD-43XF7596 starts alone, why?
Hi @dorian.hodisan Assuming you mean that the TV turns on by itself, then have you checked that the On timer hasn’t been set? Failing that, you should eliminate all your connected devices by unplugging them and see if it still does it. Also take out the batteries from the remote to eliminate that. Please let us know how you get on. I take it you don’t have a cat or dog playing with the remote.
Hi @dorian.hodisan,
Welcome to the Sony Online Community!
In addition to the tips by @LightFoot we would also recommend you verify the options below be set to [Off].
[HOME] > [Settings] > [Channel setup] > [Digital setup] > [Guide setup] > [Update Guide in standby]
[HOME] > [Settings] > [Channel setup] > [Digital setup] > [Interactive application setup] > [Interactive application]
Keep us posted!
Cheers,
Dutchice
