I have the channel banner and picture size banner staying on all the time, I have look thru various ansers on this page and get to settings but i dont have channel input menu.
It is a sony bravia tv some 10 years old and using the RM- ED009 controller.
any help appreciated
Hi @directline1, welcome to the Community.
Can you please provide the model number of the TV and let us know if you have tried a reset? This involves switching the TV off, unplugging for 1 minute, plug in again and switch on.
Thanks
Mick
Hi,
Yes I have tried the reset to no avail.
The model is KDL-32V4000
Hi there,
As far as I know, there isn't a way to disable the info banner completely on your TV, but you should be able to dismiss using the Info button on the remote.
The banner appears when the TV detect any change in the signal.
Win_88
