Connected but no internet
AlicjaE
My tv says it’s connecting but no internet. Date and time set up correctly. I am loosing it now and have no idea where to go for help. I have re set tv re set the router , unplug all cables no success
AlicjaE
Sorted. I had to manually change all the WiFi setting including ip and gateways. I copied them from my iPhone WiFi settings and it worked
Alicja Elder
Sent from my iPhone
6 RISPOSTE 6
Have a look at the post next to your if it helps
Butcherbird
How are you connected WiFi or Ethernet?
AlicjaE
Wi fi
Butcherbird
I am not an expert but I also had a problem with WiFi dropping out but have now been able to connect tv to router via Ethernet are you confident to go into router and disable ipv6 in LAN settings this may help?
AlicjaE
Alicja Elder
Sent from my iPhone
Butcherbird
Great I am glad you found a solution I did find that when I did this on Ethernet it only let me watch a movie for about 15 minutes and it dropped out hence why I went down the disabling the IPV6 on the router LAN fingers crossed .
