Bravia Factory Reset
rayc690
New
I have a 55” Sony Bravia don’t know model it’s mounted on wall and cannot get to it and nobody can visit house to help because of COVID but it’s about 7-8yrs old
What happened is that not used for years turned it on but it went into Software update mode and I cannot get out of it whatever I try.
I have attached pictures of buttons on back, what screen is showing and also the remote to see if anybody can help
3 REPLIES 3
Joe_Dohn
Specialist
I think you're referring to a continuous reboot loop, which is an old software issue.
Check out this article, I recognized the button array on the back of the TV, hope it helps!
- JD
rayc690
New
Thanks sorted now I downloaded the latest software to usb and installed it from the usb onto the tv
Regards
Ray
Sent from my iPhone
Joe_Dohn
Specialist
Hey @rayc690,
Glad it was resolved easily!
Be sure to mark your post as the solution so others can benefit from this thread ^^
- JD
