Is it OK to expect Android Oreo on 2017 Sony Android TVs?
I read your bug report and concerning WiFi issues, I found the following solution... click... Enabling "Scanning always available" in WiFi settings solved connection problems for me. This one is disabled automatically if you disable location services during setup.
@Kuschelmonschter thanks a lot, I will add it along with the one regarding ipv6. I do not have direct experience on this since my tv is cabled
Well damn. ..looks like they really cancelled bug fixing Oreo update for Europe...
They dont! Its coming, its out in US, EU is next, the Asia.
@hitta_jonte wrote:They dont! Its coming, its out in US, EU is next, the Asia.
Check posts on page 20...
Yes, but US and EU is different i think, like Tv models EU vs US. I read on reddit that its coming. I hope they right becuase right now android is a disaster on a sony tv.
Apparently they found other bugs in European release and decided to pull it out...otherwise it would be already available for download...
Sad to hear that 😞 webos is much better, never problems and smooth tv quality. I dont want to buy a apple tv.
