Does anybody know if you can use the AudioManager API to programmatically set the toslink volume?
I want to write a tasker plugin so I can link the toslink volume to the main volume.
Is there a better way?
Thanks
Hi, how do you connect the AudioManager API to the TV and what is the full model number of the TV? Can you also explain a connection map of all the devices to understand?
