Sony RMT-P1BT remote commander
gbcegae
Explorer
I have a Sony Remote Commander RMT-P1BT which is a great piece of kit. I use it with an A7 iv. The problem I have is (I use my left eye to focus) so I use the AEL button on the camera to back focus and not the AF-ON button as I tend to poke my right eye with my thumb! I would like to re-program the C1 button on the remote to operate the AEL button to the camera. Is it possible & if it is I would be grateful for this info.  Many thanks
2 REPLIES 2
I guess you need to customize the C1 Button on the Camera, then the C1 Button on the Remote Control will activate the function you chose for the Camera Button.
HannahEd01
Hey, you need to assign the C1 on the camera and the remote will pick  it as per this link: https://helpguide.sony.net/ilc/1820/v1/en/contents/TP0002240390.html
