I have just collected my A74 today and cannot format the Sandisk UHS2 card in the camera or use it in slot 1. It says that slot 1 is compatible with both CF Express Type A and also UHS-2 SD cards but my brand new camera will not recognise or format the UHS 2 card. Any tips??
Solved! Go to Solution.
Thank you Marino.
The cards are SDHC II. Strangely the cards that I use in my A9 would not format or be recognised but exactly the same card that I had in my Fuji formatted and works perfectly so all is good.
No idea what is going on unless it was a piece of dirt or something in the slot (on a brand new camera only taken out of the sealed box yesterday!!
Just happy it is now working and used it today and delighted with performance and results.
I am relieved and very happy all now appears to be fine!!
Thank you Marino.
Hey Ian5986, thank you for updating the thread. Could you mark it as solved please?
