Misaligned optical viewfinder on DSLR-A200K
profile.country.en_GB.title
sthaine
Visitor
I have always had to compensate slightly with the viewfinder - but recently it has got a lot worse. I get a lot more sky at the top of the picture than shows in the viewfinder. Any solution?
1 REPLY 1
blaireau_photo
Visitor
Hello sthaine - Welcome to the Sony Forums :slight_smile:
From what you have described, it sounds like there is an internal fault within the camera that has got progressively worse. If you camera is under warranty, you may be able to get this repaired at no extra charge. If the camera is more than 12 months old, I would still advise getting in touch with Sony Customer Services to find out the repair costs involved as you can also shop around with other local camera repair centres.
To contact Sony, please use the details on the following page:
http://www.sony.co.uk/support/en/contacts/dime
Thanks,
Simon
