Lens compatibility a77
SOLVED
profile.country.en_GB.title
manonvt
Visitor
Will the SAL 18-250 lens work well with the new A77??
Tags (2)
1 ACCEPTED SOLUTION
Accepted Solutions
GoNz0-
Explorer
sony lenses will work, its only old sigma that has issues.
5 REPLIES 5
GoNz0-
Explorer
blaireau_photo
Visitor
Hello manonvt - welcome to the Sony Forums :slight_smile:
Yes the SAL-18250 is compatible with the upcoming A77. The latest developments about this camera can be found here.
Thanks
Simon H
gspgsp
Explorer
Hi,
Does anyone know if the AF/MF electronic button works with the SAL-18250 and a77?
This is like DMF on the lens and allows you to do manual focus fine tweaks whilst in AF mode withough damaging the lens.
Cheers.
GoNz0-
Explorer
DMF cannot work with any lens that contains a drive motor.
gspgsp
Explorer
The expensive Sony SSM motor lenses work with DMF thanks to a special clutch mechanism in the lens I think, and some of the SAM motor lenses. The 18-135 SAM lens does say it is supported in the manual for it, but the 18-250 did not say as much. I have hovever since received a response from Sony:
"We have received an update on your case from a higher level advising that the desired lens model SAL-18250 supports direct manual focus but it should be set firstly on the camera in order not to damage the lens."
So looks like the 18-250 should be ok, but may need to press the AF/MF button, with the SSM I think you can just turn the ring once it is focus locked.
