dot in the picture
Hello, I noticed that my sony a6000 developed dots in the middle of pictures. I thought it was something on the lens and tried to wipe it off, but not the case.
In fact, when I zoom in, the dots fade in colour, but also get bigger. But they only appear when on Manual Exposure or on Aperture Priority. All the other modes are perfectly fine.
Does anyone know how to solve this?
Thank you!
is it safe to wipe with the same cloth I use for my glasses?
Hello @nk0342,
the back side of the lens - yes.
If you want to clean the sensor better go to a camera store and let them clean it professional.
- Nic
Hi @IamNic,
Thank you for that!
I just tried wiping the back lens and noticed something weird: there are now 2 dots, but they only appear when on Manual Exposure or Aperture Priority.
Looks like you have some dust/item on the sensor, you can use a soft camera lens/sensor cleaning brush to remove these specks from the sensor
hi @kregor1
The dots appear only when on Manual Exposure or Aperture Priority, so I'd like to believe it's not dust 😞
Hello @nk0342,
I assume it shows up if the aperture is at a certain level, could you test this in manual mode by opening and closing the aperture?
- Nic
Hi @IamNic
changing aperture makes the dots bigger but lighter (F3.5) or smaller but darker (F22). Similar when zooming.
F3.5
F7.1
F14
F22I'm gonna attach some pictures as examples, I hope you can see them.
Again, Thank you for helping me with this!
