a7r iii motion and lightning sensor
MisterSonya7riii
Member
I am looking for a motion and lightning sensor for my a7r iii, but no luck so far, does anybody know of a make that would fit this camera.
5 REPLIES 5
MisterSonya7riii
Member
Found a little gadget called Miops will do the trick.
ianpollen
Member
Have a search for Trigger Smart. This will trigger by light, sound and motion.
Ian
grahamjhilling
New
Hi there,
Not sure if you purchased a Mipops device in the end, I bought a Smart+ that I've never used and am now thinking of selling. If you're interested just give me a shout.
Cheers, Graham
MisterSonya7riii
Member
Smart+  ?
grahamjhilling
New
Yes, sorry, it's the Smart version, so wireless from the phone to the trigger. Bought on Amazon, July 20th 2018 for £174.99. I'm not too fussed about selling it but if you were still after one, it might save you some money. I've just used it in the house for testing tbh have an old trigger that I use for bulb shots (so no mobile phone).
Looks like it has come down by £5 since I bought it.
https://smile.amazon.co.uk/dp/B06WWD5236/ref=pe_3187911_189395841_TE_3p_dp_1
g
