When I remove lens cap after powering on the lens activates with short continual movements? this is shown on the live screen by (as what can only be decribed as) 'mini zoom' movement
It happens with all my lenses incl 30 mm prime, and happens with no interface from myself, quality of photograpghy not affected.
Only happens when I take the lens cap off.
Any pointers appreciated
Is not it simply to focus? If you put a hand in front of you and then take it off does not do the same thing?
