Xperia 5ii
Nottsbutterfly
New
Xperia 5ii
April-
I'm having issues with the last couple of updates, how do I remove the green tab for screenshots? I don't want it in the frame..I much prefered it on the on off button as it always has been
May-
I can't clear my notifications since yesterdays update..what's going on?
If it's not broken, don't fix it with a carbuncle..
3 REPLIES 3
profile.country.PH.title
MarlonUk1
hello @Nottsbutterfly
can you show us a picture of the green tab?
and also what notifications are on?
Anonymous
Not applicable
You can try to force restart the device as well (for the notification issue) and check again, you can press on the power button and volume up key until the device vibrates once.
