WH-CH710N
KEENGMK1
New
WH-CH710N
Are there plans to make the Sony Connect app compatible with the new 710N headphones? Little frustrating they arent compatible at present!
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
Welcome to the Sony Community.
I'm looking into this and will update the thread when I have a answer.
Best wishes,
Sean
Joe_Dohn
Specialist
The Headphones Connect app is primarily designed for wireless headphones, so I think it'll happen eventually, might just be that it's a new release. It's probably a good idea to stay tuned using their support app though, it's called Support by Sony, It's always included at the bottom of their device support page, here's the link if you need it: https://www.sony.co.uk/electronics/support/articles/00204426?cpint=spt-subfooter_sbs
