WF-1000XM3 window 10 issue
SOLVED
chmacdo84
Explorer
Hi,
I am having trouble pairing these to a Windows 10 laptop. They don't appear to show up as an audio device. I would try updating the firmware, but the link to it has been removed.
Any help would be much appreciated as it seems impossible to actually get hold of someone that works at Sony.
Many thanks,
Chris
1 ACCEPTED SOLUTION
Accepted Solutions
chmacdo84
Explorer
Update: Just this morning Sony has released a firmware update and it works for me. Finally! Can now use the headphones as I originally intended!
11 REPLIES 11
Pascale_F
Moderator
Hi Chris,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Chmacdo84,
I believe that Sony will release a fix for this in the next update.
Cheers,
The_Black_Rose
chmacdo84
Explorer
[edited] Ignore
calille22
Explorer
I have paired my headphones to my windows 10 laptop without any issues.
Yes they do not appear under available audio devices, so you just click on the Add Bluetooth or other device, then select the first option Mice, keyboards, pends or audio......  Hey presto the headphones appear!
Sorted for me.
Carl.
chmacdo84
Explorer
Yeah, that doesn't work. Which is why Sony are issuing a firmware update to fix it.
chmacdo84
Explorer
~A month has passed.
Still no fix issued. Still can't use on Windows 10. Still disappointed.
profile.country.DK.title
Styxor
Explorer
And absolutely no information about, if and when they will release a new firmware update.
Sony doesn't care about their users.
chmacdo84
Explorer
temmens
New
Hi there, you say this has been fixed, but the audio quality when I connect my earphones as the "headset" is trash - is there another way to do this?
