VGN-A295HP -> Problems with DVD-RW
Dreadly
Visitor
I have just bought a new sony laptop with a dual layer DVD-RW and it does not eject using the big eject button. just the little one on the front of the drive.
There is a little orange lite glowing under the dvd drawer front permenantly.
Is this a hardware fault, should I return it or call the support line?
Is this something really stupid I am missing?
Andy
3 REPLIES 3
profile.country.en_GB.title
kee-lo_
Member
Make sure you install the UTILS.EXE before returning it, you could fix it.
Its found on the recovery CD and on www.vaio-link.com
Dreadly
Visitor
Thanks for the reply, I have run utils.exe, but it locks up at 91% installed......
I cannot run it fully, maybe this is the problem?
Andy
kee-lo_
Member
Have you installed Alcohol 120%?
If so, make sure you set the DVD as the primary device not some virtual disk.
