Need some help vaio camera
Hi everybody. i would need some help. I have a VAIO notebook VGN-FE41S and i have a problem with the cam. Every time i try to use it appears this: An Attempt to initialize de camera failed. Please check if another software is using the camera. i dont no what's the problem because i've never used it. What should i do?
13 REPLIES 13
Stubie
Visitor
That file has no instructions or information in it outside of your own personal data... You might have uploaded the wrong file or something.
I'm still having this issue, what was the resolution? The hotfix pretends it doesn't apply to me. 😞
RJanner
Visitor
Ah sorry, I have attached the file again, hope this solves the question
jaigill
Visitor
Attached is a hotfix by Microsoft. Note that it is in BETA. However, it completely eradicated the problem of "camera failed to initialize" for me. I have VGN FZ11Z running VISTA. Let me know if it works for you. Note: More info on this hotfix is found here:
http://support.microsoft.com/kb/931812
benthom99
Visitor
i have the same problem but with the VGN-FZ21E i had a look at the step by step guide but there doesnt seem to be any advice on there :S
