A117S CD burning problem
grandi
Visitor
I have several problem copyng CD at 8 x speed.
Often the following message appears :
Creating Image completed successfully
Burn process started at 8x (1.200 KB/s)
Invalid field in parameter
Could not perform start of Disc-at-once
Burn process failed at 8x (1.200 KB/s)
the same cd are burning correctly whith the same software in a desktop PC.
I am using nero v 6.6 on XP SP2 operating system.:smileycry:
4 REPLIES 4
Zamir
Visitor
change the option to track that should work
profile.country.en_GB.title
kee-lo_
Member
Make sure your files names are not over 256 characters including directories.
Cala
Visitor
Are you using sony cd's? I find they work better with less problems.
kee-lo_
Member
Also reinstall your DVDs driver by right clicking My Computer > Properties > Hardware > Device Manager.
Then open the DVD tree, right click the drive and click uninstall.
Restart the PC.
