Viewing light meter while adjusting iso in manual mode
SOLVED
bavarian1
Explorer
I don't seem to be able to view the light meter on the viewfinder or rear screen while adjusting the ISO in manual mode on my A7 Mk3 is it possible ?
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Tenneen9000
Member
Hi bavarian1,
That's strange. It should be available when setting ISO to anything but auto with manual exposure as explained here. If this is not the case with you, can you share with us the settings you're using in more detail?
Cheers,
Tenneen9000
1 REPLY 1
Tenneen9000
Member
Hi bavarian1,
Cheers,
Tenneen9000
