A7III Extended Warranty
musicmonkey
New
Hi, I bought my A7III from Jessops which included a three year extended warranty, Im not sure how to activate the 3 Year Extended Warranty, does it automatically extend to 3 years it when I register it?
Thanks
5 REPLIES 5
Pascale_F
Moderator
Hi musicmonkey,
Welcome to the community.
Is the extended warranty a Jessops care plan?
If it is, you would need to get in touch with Jessops regarding this.
Thanks,
Pascale_F
musicmonkey
New
I’m not sure as all the major retailers offered the same 3 year warranty with a pre order, which makes me believe it may be a Sony offer?
Danno11
Explorer
Hi,
I also bought mine from Jessops.
In the box was a card similar to a credit card with an activation code on which you scratch off and register with Sony for your 3 year warranty.
I also purchased from Jessops the FE 24-105 F4 G oss lens which I believe was included in the 3 year warranty however the activation process  did not give me the option to include this so I just registered it with Sony in the normal way.
Hi all,
can anyone explain how to activate the warranty? any time I give it a try pushes me back say " did you check the model name".
I'm pretty sure all the fields I enter are correct.
Any suggestions?
Many thanks!
you mean, you just registered the camera body but not the lens?
