24-70 2.8 GM with A7RII
bushcraftkid
New
Please can anyone comment on whether it is possible to use a 1X or 2x teleconverter with the above setup?
Thanks
Bushcraftkid
2 REPLIES 2
Pascale_F
Moderator
Hi Bushcraftkid,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi bushcraftkid,
I believe that the lens is not compatible with a teleconverter. I've just had a look into the compatible accessories and it's not listed.
You can check this link for all of the compatible accessories with the lens here: http://bit.ly/2H1m8qN.
Also. I've checked the 2 teleconverters that Sony manufacture: SEL20TC ( 2X converter) and  SEL14TC ( 1.4X converter) and found that it is compatible only with few number of lenses, I recommend checking the below:
-SEL20TC: http://bit.ly/2GIgUBc
-SEL14TC: http://bit.ly/2tC8xhK
Cheers,
The_Black_Rose
